Gobstopper
I was able to update the caps and transistors on the Mic Board and it didn't help the hiss problem
, I was really hoping this would take care of it. As a reminder, hiss is in both channels, the hi-cut filter reduces it(as does the dolby NR switch), and if I remove the pre/main jumpers the hiss isn't there. I updated all the electrolytics and transistors on the Control Amp and the EQ board and on the power supply board(but left diodes and resistors alone). I should also mention that there is blackening on parts of the power supply indicating that there was some heat damage at some point. I was playing with the volume knob, and it seems that the hiss slowly increases with volume until a certain point, and then as I increase the volume it suddenly jumps in intensity or gets much louder. The hi-cut filter and dobly NR help at the lower level of hiss, but not as much after the big jump. I deoxited + faderlubed the volume pot, which reduced some crackling, but no effect on the hiss. At this point I don't have too many other ideas of how to proceed
. Is there part of the power supply which feeds the control amp but not the main amp? I've run across mentions of using a scope, but don't have access to one. Is there a poor man's signal probe approach?
Thanks,
Gabe
. Is there part of the power supply which feeds the control amp but not the main amp? I've run across mentions of using a scope, but don't have access to one. Is there a poor man's signal probe approach?Thanks,
Gabe
