bzenic
Here is my current situation: I don't have any output from main amp.
The tuner works fine and there is a good signal from Pre-Out RCA, I've tested that by connecting Pre-Out to another receiver AUX input. There is no any output on Phones jack as well.
The voltages on the protection board look good as well.
I have tried testing transistors on the main amp board without desoldering them by measuring diode fall between E-B and they seemed okay.
Testing the output transistors on the sink the same way was inconclusive.
Is there a reliable way to test the output transistors on the sink without desoldering?
Should I trace a signal from the signal generator?
