Gobstopper
Hello Everyone,
I've been off the forums for sometime, and decided to go back and revisit my old SX-838 which I thought was mostly fixed for a bit (other than the FM), but started up with new symptoms. It's hard to describe, but a few minutes after turning the unit on and playing music through it, there is an odd whooshing in the background(aux, fm, tape). It's not static, and is independent of me fiddling with any switches or knobs. Last time I tried it a few years ago, I could hear some bleed through of FM while using other inputs, not sure if related or not. If I plug a source directly into the main amp(via jumpers in the back) the sound is clear. Thus, the problem is upstream of the main amp. Does anyone have advice on where I should start probing voltages or other things to look for? My plan going in was to test voltages on the control amp board(AWG-029), but I looked in the service manual and there aren't any voltage listed as there are for the main amp. I also looked through the forums but didn't find any too many specifics on troubleshooting the boards upstream of the main amp.
Thanks in advance,
Gabe
Thanks in advance,
Gabe
