vwong688
Hi,
There are lot of things going on on this SX 850 I am trying to restore.
I have replaced the capacitors and transistors according to the parts lists floating around on AK. I have to admit because it was my first time attempting electronics work like this, mistakes were made.
After initially restoring the power supply board, it was working great for a period of time until I decided to dial the BIAS in. This caused a capacitor that I had installed backwards to explode. With my BIAS in adjustment no mans land now but a new capacitor replaced in, the relay no longer clicks. I have gone ahead and recap the protection board which was very straight forward and I feel very confident with what I did.
Some other work I have done was switch out the old speaker terminals for new Banana ones. They were working fine after the work, before the exploding cap debacle.
Here are the readings for my power supply board right now. Note: I can't keep a fresh fuse in FU4 without it burning out immediately! This started happening after my novice hand shorted some pins while trying to take measurements....
Power Supply
1: 0
2: 0 (5.4v)
3: 0 (5.4v)
4. 4.3mv (13.9v)
5. 4.2mv (13.9v)
6. 65.6dcv (51.5v)
7. 65.6dcv (51.5v)
8 47.64dcv (36.5v)
9 47.64dcv (36.5v)
10 47.5dcv (36.5v)
11. 36.74dcv (28v)
12 .5 mv
13. -13.04dcv (-13.5v)
14 -51.58dcv (-51.5v)
15 -18.75dcv (-19v)
Protection
2. -13.28dcv (-13v)
9. 47.43dcv (35v)
10. 47.45dcv (36.5v)
11. 47.48dcv (36.5v)
12. 7.7acv
I have a spare power supply board at hand that was extracted from a confirmed working unit. It looks to have its Q7 and Q5 replaced before as well as new capacitors.
Given all the bad work I may have already done to the existing board, can I have some advice about attempting to switch the boards. I can see that I will have to resolder a lot of pins. From reading the forum, I have found it it is best to not undo the wire coils where there are.
Any wisdom will be greatly appreciated!
Power Supply
1: 0
2: 0 (5.4v)
3: 0 (5.4v)
4. 4.3mv (13.9v)
5. 4.2mv (13.9v)
6. 65.6dcv (51.5v)
7. 65.6dcv (51.5v)
8 47.64dcv (36.5v)
9 47.64dcv (36.5v)
10 47.5dcv (36.5v)
11. 36.74dcv (28v)
12 .5 mv
15 -18.75dcv (-19v)
Protection
2. -13.28dcv (-13v)
9. 47.43dcv (35v)
12. 7.7acv
