vwong688
Hi
I put a new Power Supply board in my unit about a month ago and everything has been great, barring an issue with the left channel being slightly weaker than the right. I did perform a DC offset when I had the cover off and thought I did everything correctly. I had also done a rebuild of the Power Protection board, caps and transistors.
Yesterday while listening to the tuner on very low volume, I head a Thump and the unit relay clicked off. I noticed that after powering down the unit for a few minutes and turning it back on, the relay clicks but then trips. Subsequent attempts to turn on the unit after doesn't cause the relay to click anymore. I had a new relay laying around but hadn't put it in yet and so I did that today. Same exact symptoms.
Here are my readings:
Apologies, I couldn't find the specs for the blank Protection Board pin outs. I was getting fluctuating read outs for those, am I correctly grounding it while reading to the chassis?
One thing that sticks out is Pin 9 on the protection board. I had was reading it when I turned on the unit after it being off for some time. The reading was coming down to I believe to the spec reading and the relay clicked. When the relay tripped again, the value rose to 36.4 v DC.
Am I correct in thinking that at this point with the relay fully tripped, I can't adjust the Idle and DC Offset?
I know this is a well covered topic, I read some posts but couldn't find diagnoses that were exact to my symptoms.
| AWR 101 | Spec | Test |
| 1 | GRND | GRND |
| 2 | 5.4v DC | 5.08v DC |
| 3 | 5.4v DC | 5.1v DC |
| 4 | 13.9 DC | 13.34v DC |
| 5 | 13.9 DC | 13.36v DC |
| 6 | 54.8v DC | 50.9v DC |
| 7 | 54.3v DC | 50v DC |
| 8 | 37.6v DC | 36.34v DC |
| 9 | 37.6v DC | 36.34v DC |
| 10 | 37.6v DC | 36.36v DC |
| 11 | 28.8v DC | 28.1v DC |
| 12 | GRND | |
| 13 | -13.0v DC | -12.96 |
| 14 | -50.7v DC | -50.2 |
| 15 | -18.5v DC | -17.89 |
| AWM-062 | Spec | Test |
| 1 | Fluctuating | |
| 2 | -13.1v | -12.97 |
| 3 | Fluctuating | |
| 4 | GRND | GRND |
| 5 | Fluctuating | |
| 6 | Fluctuating | |
| 7 | Fluctuating | |
| 8 | Fluctuating | |
| 9 | -0.9v (relay off) | 36.4v DC |
| 10 | -0.9v | 36.4v DC |
| 11 | -0.9v | 36.4v DC |
| 12 | 7.5vAC | 7.5v AC |
