Its a shot of one part of launch range controller's console for commercial launch vehicles (ie Delta II, Atlas 2AS, etc), hence able to take a shot.
..on the SR-71, it always came down at ambient temperature, some have told stories about being too hot to touch for awhile. It essentially enjoyed a 15 minute or more subsonic decent from 30K Ft on down, so had ample time to get cool to the touch.
SX-950-
I found that the four left channel transistors are all shorted, right side indicates proper voltage drop with meter in diode check mode. The #s are 2SD427 and 2SB557.
Here are some shots of the power amplifier assembly rotated backwards, after removing 6 hold down screws (3 each side-can be seen in picture).
La Mesa TV Supply in San Diego has them in stock, 4.95 for the NPNs, 8.95 for the PNPs.
Don't use them !!!!!! The chances of counterfeits is wayy too high, even if the shop is a good guy....
use these from mouser.com, they are tried and true, and we can count on mouser and digikey not getting tricked with counterfeits:
863-MJ21193G pnp to-3 250v 16A 250W 4mhz 8-75hfe $3.83
863-MJ21194G npn to-3 250v 16A 250W 4mhz 8-75hfe $3.83
(2sb557........ pnp to-3 120v 8a 80w 7mhz 20-140hfe)
also get:
534-4662 to-3 mica insulators $0.16 each
534-4673 to-220 mica insulator $0.14
532-249 1 oz thermal compound $4.71
I don't think 1 gram is going to be enough: 526-NTE303 1 gram thermal compound $1.77
we have lost count of all the units these have successfully gone into...
get 8, do all the outputs, they are very robust.
BUT, now we have to address WHY they blew.... ALL 4 implies a very serious bias problem.
The simplest way to state this is to just test the transistors on the amplifier board, Q5 - 11 or Q6-12 depending upon the channel, also check for burned up or open resistors around them.
I'm not sure if the drivers (q9-11 or q10-12) are to-66 or to-220 so a picture of the amp board would be welcome.
The circuit (r35, Q5, D5, VR3, Q7, R71 or it's counterpart on the other channel) are CRITICAL in establishing the +1.2v and -1.2v bias voltages, if the circuit is broken, the +/- 1.2v becomes +/- 30 or more, turning on BOTH sides of the output transistors at the same time, making a massive short across the raw dc.
The sx-850 and sx-950 amplifiers are almost identical and use the same parts, so here is a complete semiconductor replacement parts list for a sx-850 I did recently:
http://www.audiokarma.org/forums/showthread.php?p=1875117&highlight=863-MJ21193G#post1875117
edit: notice I said the same thing as EchoWars, but his post came in while I was researching mouser's stock & price and typing in the results...
