SX-950 channel cut out
D.E.K
Loader
Hi,
I thought this was happening with only the SX-950 but I was wrong. When I turned the volume up to a certain level, the relay in the SX-950 keeps cutting in and out periodically. I hooked the same record player and PC to my SX-680 and the left channel is very weak and somehow distorted at high volumes. I also switched the Left and Right Speakers at the speaker outputs, same thing. I switched the Left and Right input cables, same thing. In every case, whether the balance knob is Left or Right, my left speaker is weak. The little L/R Power Meters on the SX-680 are identical at every volume levelSpeaker problem I guess. Any ideas?
Thanks a lot.
The power meters are calibrated to an 8 ohm load, and if the load is heavier (like with a failing speaker) there would be no indication until the overcurrent protection shut it down or the outputs fried.
What type of speakers are they? It could be a driver or a failing capacitor in the crossover.
Cheers Mike. The speakers are HPM-100's. It was the speaker wires after all. Ages ago I conected 2 pieces of speaker cables to test something and somehow forgot all about it. There either was a poor connection or the bares were touching eachother. I replaced the speaker wires and she is great. I also took some readings as Chris adviced. All three speaker outputs read the same: Left 0.10 and Right 0.24. I am not sure if these are halthy numbers.
:dunno:
WHAT readings? what UNITS?? Volts, millivolts, ohms amps, milliamps?
This is the problem about splitting threads, having to look ALL over to figure out what is being said.....
WHAT split threads??? There's only TWO. SX-1010 and SX-950. Would you rather discuss SX-950 in SX-1010 thread? No sweat we can do that. Just thought it wouldn't be appropriate.
The readings of speaker terminals are 24mV and 10 mV. Unit powered on in AUX with no input or speaker output. Volume at 0.
Whoops, my bad.... :stupid:
Those readings are good. They can probably be adjusted lower, later on.
I should have clearified. I sent Chris a PM yesterday asking how to take the readings. I asked in private because I didn't want to ask a foolish question and look like a real dumbarse (I am sure I looked like a real dumbarse quite few times up to this point) in the main thread. Yet again as Chris suggested, I might make the adjustments shown in Section 9.3 of the service manual. Of course SKIPPING the BIAS adjustments and NOT TOUCHING those settings. Step 2, 4, 5, 6, 7 and 10 only.
Hi again guys, I know this is totally irrelevant to the subject of this thread but... Is this rediculous or what? Is this a joke or a gimmick?
eprey link removed
typo. get rid of the link b4 this whole thread gets dumped in $ & c's
