I know there a lot of similar posts and I've read through many of them, but I still can't figure out the problem. When I turn on the unit the relay never switches on and no sound will come out. I checked the pre-amp with a separate amplifier and it is producing good sound. I've checked all the voltages from the pins on the protection circuit, power supply and power amp, and everything checks out. I also checked the transistor voltages on the protection circuit which appear fine. I also checked them using the diode function on my multimeter and they seem to have the appropriate responses. I'm about to take out the relay switch itself to see if there is a mechanical problem, or maybe corrosion, but from the exterior it looks quite clean.
My question is other than the relay switch, what could possibly be the problem? Would it be worth it to just rebuild the protection circuit, despite having good voltages? What else can I check?
Here are the voltage readings: (The first column is pin#, second column is listed voltage from the service manual, and the third are the actual readings. The transistors (Q) have the base, collector and emitter denoted by b,c and e.)
All the caps and transistors are original (except for the Eq board, which I rebuilt several years ago with the help of Mark the fixer).
Thanks for any input!
