SX-950 Output replacement
joey1355
my sx 950 just got a new replacement for the output amplifier. just blown a few minutes ago. is sx 1250 output matches my sx 950 output? i think its much powerpul or much higher rated, but is it ok if i use a much higher transistor? or please advice me for whatt should i do. thanks
You may want to consider replacing the driver transistors as well while your at it. Something caused the outputs to blow, maybe it's somewhat common? In some designs the drivers actually do more work than the outputs. EW would definitely know better than I would.
Good point. When outputs go, they usually take something with them. Best check it out thoroughly
