Was this functioning properly before the re-cap started? If so, and you do indeed have a dim glow after the main caps charge, I would go off the DBT if needed. However, you can figure that the supply voltages will the low, but anything less than that should be pretty close,
If it's not going out of protection I would leave it on the DBT and look for widely divergent voltages -- for instance, high DC on the output causing the protection circuit to shut things off. Voltages on the test points of the protection board should be close to what is in the schematic except the main power on "signal" -- not familiar with that circuit, someone else with more experience will pop in sooner or later.
If you find a voltage that is positive instead of negative, or some volts instead of zero, trace back through that part of the circuit to find out what's "broken".
I have a Technics SA-310 I'm working on right now that has no output on one channel. Appears to have internal circuitry in the STK module that shuts off the amp circuit if the ouput exceeds normal without muting the other channel, and I found 2V on the input of the power amp and on the output of the voltage amp section -- waiting on parts to pull it all apart again to test the bias diode and current gain transistor on that little subsidiary board. Either the diode is bad switching the transistor on, the voltage amp is shorted (it's an IC in this receiver) or the transistor is leaking badly. Known problem transistor, too. Same story in my Yamaha R-700 -- in that case I had 35V all over the place on the STK for that channel plus a smoked resistor, and 35V (or -35V, don't remember) where I should have had zero in the protection circuit from the ouput. Sure enough, the STK is shorted to the rail supply internally.
This is what I mean -- a voltage far off from what it should be rather than just lower on the rail voltages is a clue for where to look.
