SX1250 AM antenna info needed..
Kuch73
I have a 1250 that is missing the ferrite AM antenna in the back, as in everything is gone, no wires, antenna, or holder. I would like to find at least the antenna and wiring part to replace it. Where inside does the wiring go to from the antenna? If anyone has a nice pic, that would be helpful. Thanks
Your going to have to buy the entire assembly from a parts seller. The wiring is connected to the tuner board and will require the schematic. When I see the Assembly for sale the wires from the antenna are cut way to short: You will have to add some length to the leads to reach the posts on the tuner board. Maybe your set has some of the harness left?
attachment.php
attachment.php
Those pics are great, and thanks for the info on the wires. I will have to check mine underneath to see if any is left on the board.
