I'll start with the question and then fill in some history. Having done some work on an amp and checked it to the best of my ability, I decided to power on with a DBT. Sadly, the bulb glowed constantly (not very dimly). Hopefully, parts were not damaged. No fuses were blown, no magic smoke released. Diagnosis seems to be a short somewhere, but where? My question is: what is the next troubleshooting step, if the DBT fails?
This is an SX980 that was working nicely until one day the relay stopped clicking. Foolishly, I completely disconnected the power supply and amp boards to gain access (do not repeat my mistake -- they are accessible in place). I recapped the boards and reconnected only the power supply board. After working through some problems, with MTF and others, we got the voltages correct. The relay even clicked. Then, I connected the amp boards, along with the many other sundry wires to the power supply. I tried to be careful and double checked each one. But, when I flipped the switch.... light! :sigh:
My current thinking is that either I made a wiring mistake or there was a problem on the amp board that caused the original cascade of ruin and which, not having been fixed, only returns when the beast is brought back to life. I'm pretty confident on the wiring (80%?) so I suspect the latter. All this brings me back to the original question : what to check next?
Many thanks in advance. Without the kindness and generosity of the members here I would be lost.
