Syntec S-220 Null Point/Alignment Recommendations
Isaac C.
Cat Hoarder
Hello everyone, now that I've got my Syntec mounted and setup, I've been trying various protractors to find one that works the best. Which alignment should I use? I was using Lofgren, but I just tried Stevenson and was able to pull it off although the cartridge is angled fairly well in the headshell. Here are the specs:
Pivot to spindle 202mm (factory says 205mm, someone on another form posted about this tonearm and said to mount it a little closer for more options).
Effective length 220mm
With Lofgren overhang is around 17mm, with stevenson it is probably closer to 20mm.
I do not think I can pull off the Baerwald, the outer null point is further than I can adjust.
The question is which alignment method will work and sound the best.
Thanks!
Yeah I found it another site, it says 62 and 102.9, but I'm wondering whether these points are as good as say Stevenson or Lofgren.
If I use those what the best way to go about that? I was thinking of using graph paper and measuring from a point I will poke out as the spindle hole then measure to 62mm and 103 mm and use the grids to align the cartridge.
Stevenson alignment is best for this arm. Remember this is a broadcast 9" arm. And also remember, the Stanton 681 EEE or 681 A is what this arm is designed for at best, or the Shure M 75 EJ or similar. Track around 2 grams, medium mass, and elliptical is high end and you're correct.
