Systemdek 2 (or II) Belt recommendation
Hifibythekg
Hi,
Can anyone recommend a supplier of good turntable belts?
Also, the existing belt has begun to ride out of position on the drive pulley. It tends to ride down a bit to towards the 45rpm slot and so turns the platter at a higher speed.
Will a new belt probably fix this?
Or can anyone offer some additional advice?
Am based in the UK.
Hi,
Am based in the UK.
before you do that check to make sure the suspension is properly adjusted. Improper adjustment can result in the belt traveling up or down.
