I have the left bias voltage at zero and the trim pot has no affect. Right channel is fine.
Paranoid working on it since the v-fet's are not replaceable. Any suggestions?
I did the Diode and resistor upgrade. I did not check the bias prior to the upgrade due to I thought everything was functioning.
I see some crossover distortion on a sine wave but now I need to figure out what the culprit is.
Thanks in advance.
All resistors and diodes checked good on board testing.
Thanks in advance.
