I removed R158 (5.6K) and R159 (4.7K) from the following:
R158....Pin 3 of V22 and the terminal strip on the other end of the resistor.
R159....Removed from the terminal strip end terminal that had the other end of R158, and the next terminal.
Then setup the new 10K pot(NOTE: Dave originally spec'ed a 5K but I didn't have 5K so useda 10K just for testing) with a 3.3K resistor on pins 1 and 3. Solder and heatshrink to reduce/remove shorts potential.
The Wiper lead on the pot attaches to the END TERMINAL of the STRIP where I removed R158 and 159. This will still have 2-330K (R150-151) resistors and the wire to the mirror circuit on the other channel.
One resistor will attach to pin 3 of V22 and the other to the next terminal on the strip. I initially set the pot to 1/2way, and connected meters to the junction of the wiper terminal and Pin 3 on V22. As it was warming up I adjusted the pot to maintain 20.5V to 21V or as close as i could get. (With a 5K I'd have a little more rotation for adjustment). It settled down after about 6 minutes. Voltages shown are after 10 minutes.
VOLTAGES
WALL VOLTAGE 111VAC (Direct to wall socket). Selector Mode in FM-AM with no Signal at antenna leads, Mono-Stereo switch in STEREO, Volume @ ZERO. I can redo it all on the variac @ 117vAC if needed.
Pin 7 365VDC
Pin 9 320VDC
Pin3 21.16VDC
Pin2 varied between 10.26 and 10.32 depending on tube.
Pot Wiper 10.86VDC
V17 Pin-4(HTR) 20.58VDC
V18 Pin 4(HTR) 10.68VDC
Tube draw in mV across 10 ohm r
V15..........337.1mV
V16..........360.8mV
V21..........358.2mV
v22..........301.1mV
These voltages are after 30seconds to settle down.
I'm going to re-arrange the output's so they are better matched. Swap V22 with V16. Also I have 7 other 6p14p-EV's that I can swap in to see if I can come up with a closer matched quad based on tube draw.
ma's
V15.....33.71mA
V16.....36.08mA
V21.....35.82mA
V22.....30.11mA
Subtract 3ma for grids/screens and get
30.71
33.08
32.82
27.11
With 365 on the plates, these figure to be ABOUT.....
11.21w
12.07w
11.98w
09.90w
A bt more spread than I anticipated considering the #'s I got Tuesday. But with all of the voltages closer to their intended nominals, it's probably the tubes showing their age. Anyway swap V16 and 22, re-check the numbers and then check the other 7 (pull the worst one in there now and rotate thru the bunch and see if there is a better tube.).
Larry
