HatoftheCat
I'm trying to replace the original MPX decoder board in my 1964 vintage B&O Beomaster 1000 which is pretty noisy with one based on a TA7343AP chip. The original board connects in via an old style tube socket noval connector that provides -30v DC rail and Chassis GND. Other pins provide the MPX signal, the L & R output audio and connection to the stereo indicator lamp. The lamp is an incandescent bulb attached via a resistor to the -30v rail and on the original board is switched on by an AC128 transistor that provides route to ground when switched on. I do not intend to replace the incandescent with an LED and want to retain the simple noval plug connection so my new board will be a straight swap that I can apply to receivers of this same model (many of them never had stereo decoder board fitted as it was a paid for optional extra). To provide the power supply for the TA7343AP circuitry I am using a RECOM RS-2409S to provide me with a +9v supply relative to the chassis ground. Currently can see the voltage at pin 6 the TA7343AP drop down to 0.7v as expected when tuned to a known good stereo station but scoping the L/R outputs shows same audio signal on each so still mono. How do I check for 19/38kHz signals on this chip ? Has anyone experience of using this chip and getting it working in vintage equipment ? My design uses the pin 6 connected to LED side of a PC817 optocoupler the other side of which drives the gate of an IRLZ44N switching the indicator lamp on/off, schematic attached.
Is there a mismatch in the MPX signal that is coming from the tuner section and what the TA7343AP expects ? If so how would I and resolve that or is it the impedance of the source that's the problem ? Datasheet just says 200-700mVRMS
