I took apart my 3001A to fix a stuck tuning system, which seems to have been successful.
(I pulled out the piece in the middle and sprayed various cleaners and oils while gently turning. It barely could move before and now moved in response to the tuning dial. Rewinding the string confused me a bit, but it got done. I just moved everything to the far left and got the string tight there, and then wound the other end by turning the black spool thing)
Problem is, I took off the front and back covers and had numerous buttons and springs fly out. The preset buttons don't seem to use springs. I put springs in the four buttons to the right and they seem to be working, but that was all the springs I found.
Now the power knob works only if I hold it in: it goes on when pushed, but comes out and the unit goes off when released. Did I lose a spring? How is the power button supposed to be configured?
I hope John will answer cause you seem like an absolute Tandberg tuner master!
