Hello,
I am glad about the possibility to register to this legendary forum.
Can I ask for the help? I obtained Tandberg TR-2030 which I like much. While the AF part seems to be OK, the tuner has some issues. For example, after the powering the receiver On, the Signal Strength indicator moves to a constant position and stays still regardless of the station I try to tune to. Here I attached the HF section diagram and kindly ask you to advise which elements should be checked.
TIA.
TIA.
