pari57
Member
Hello,
I've already read the posts about the Tandbergs in the forum, but there are still some questions I have.
Maybe they are not significant for Tandberg alone and also apply to other brands, but that, I don't know.
so
here I go.
In one of the posts was mentioned. when exchanging caps, keep capacity and voltage as they are best don't move more than 1 step away from original value.
this sound logic.
But what if the specific cap can't be found?
to make it more real take this example
On the TR 2045 the 25 volt power line has 2 Plessey caps 100uf 40V beautiful green
I am sure the thunder & lightning sounds coming from my speakers in quiescent position indicate that I should change those (among with others of course)
But Tandberg must have had a reason to use a 40 volt part instead of the more usual 35 volt or 50 volt parts
So what to do here. 100uf 40 v is not available.
so where do we go? keep the voltage and change the value or change the voltage and keep the value.
and if so what way up or down.
e.g.
Choosing 35volt will overload the cap most of the time, even if it can have 35 + 20% = 42 Volt
On the other hand will it cut the max voltage at 35 volt instead of 40v before and even-though the regulated voltage is 25 volt. far lower than the caps voltage
Danger here is that the cap might wear out more quickly. short lifespan
Choosing 50 volt gives the cap a more relaxed life. a long life span, but it might interfere with the reaction speed of the system. loading a 50 volt cap takes more time than a 40 volt (think in light speed not human speed)
does it affect the rest of the system?
The same goes for the 2 main caps for the power amp line. Elna 10000uf 50V black neg.35x70mm
the modern caps are much smaller 30 x40mm and probably not as robust as the old ones.
Another thing I wondered abut is the variation in cap voltages throughout the assy's.
on the input board C507/508 are only 6,3v but C515/516 are 63v ???? and in between we have
C501/502 at 35v and C509/510 at 25v
so where is the logic here.
especially why the 10uf @63v make me wonder. btw the are spread all over the machine like that.
As you can see some questions that I would liked to have answered.
when there is some one around who can ? I would be grateful
regards
Paul
so
here I go.
this sound logic.
e.g.
regards
Paul
