Tangent T-4000 recabinet to SuperHeresy 2.0
SgtSlasher
Been reading this as well as the old Klipsch Forums…. Thinking about committing Heresy…
original owner of T-4000 bought back in 94 in Frankfurt…. Wife hated them always… at some point one of the kids or their friends managed to poke a hole in the woofer… and into the garage they went… want a smaller speaker and my Onkyo Amp Preamp M304 has plenty of power to drive them…
Have the Crites
-titanium tweeter upgrades
-new caps
-CE-1228 Woofers
Cabinet is peeling and so I might as well build new Cabinets with real veneers and am considered more of a Heresy but 24 inches tall… and adding two ports in the back… or maybe using a shelf on the bottom ala cornwall design… I thought of putting a shelf in to separate the box to separate the squawker/tweeter from the woofer .. not sure if I would need some 3in holes to give air volume for the woofer…
Then researching I came across you guys and the Super Heresy…
I know that I don’t know ‍♂️…. Since I am a decent technician/woodworker, but no audio/sound engineer…
So most of y’all are way smarter than me…
I’m asking for opinions and advice…
MDF or Baltic Birch?
just do super heresy build?
rear port with take offs from the T-4000? Or forwards? (take offs or Corwall clones )
I’m so confused by it all and since some of you have forgotten more than I have ever known…
Guide me in a good direction
Just do a Super Heresy build. It's still on the Klipsch Forum AFAIK (I'm the originator). Everyone that has built or modified original Klipsch Heresys from before 1982, have been amazed by them. I have 3 pairs for surrounds and 2 pairs of the commercial ported versions.
If you're going to do a Super Heresy, you'll want to replace most of your parts, except for the mid horns and drivers and possibly the ports. Everything else will be sub-optimal. You can certainly try it with what you have, but as @ClaudeJ1 frequently says, "different is not the same." The woofers in particular, if they perform similarly to the Heresy spec, will be too boomy and indistinct in the bass, in comparison to the woofers that have been tested in Super Heresy mods. The titanium diaphragms may be an improvement over stock, but they also may deliver the dreaded titanium ringing and might possibly be a bit fatiguing- I'm speculating on this based on my limited experience with titanium drivers; ymmv. At any rate, if you do a super heresy build, I would maintain the stock cabinet dimensions, rather than doing a larger box as you've alluded. You may be better off replicating the boxes you have and doing a super tangent, instead; at least that way, you know you're dealing with proven dimensions and components. Once you have the speakers more or less restored, then you can try swapping out components- a better spec woofer, @Daveintn 's amazing tweeters, a universal network, etc.
Baltic Birch for sure. It is the very finest speaker cabinet wood out there for strength and durability and also, in my opinion, sounds better then other woods or glued up sawdust MDF junk. Having handled a couple of hundred old school Klipsch speaker sets now and seeing what happens to plywood VS glued sawdust I just simply stopped looking for later model MDF Klipsch speakers to fix up. Always problems with them.
Every speaker cabinet resonates, some more then others. Those who say they have completely killed cabinet resonance are only kidding them selves and what they have done is reduce the resonance or change the resonance tone to something they prefer more. However resonance can be a useful addition to your build when it is pleasant to the ear and that is precisely what BB does. Here in Nashville there are two types of material that dominate the speaker builders worlds. One is MDF for bass thump boom boxes and the other is for speaker cabinets for great music replication or live sound and they sell tons of BB to those people.
Gigantic is right. Claude knows what he is doing and he has laid out what you need to do. You vary from that don't expect the same results. I have benefited from his expertise and learned to believe his data.
Gigantic
I would build a better Tangent cabinet and be happy… But Honestly, i think that my kids despite being 16-24 years old would have another accident… (not that my wife who prefers a kitchen radio for background noise…would sabotage my speakers that take up too much room) They’re just too big for my space… honestly!
another problem is that log jome living creates a pretty harsh environment for sound especially when played loud… oak floors, log exterior walls, tongue and groove interior walls
Log beams and 2 1/2 tongue and groove on top of that…
recapped the C-overs.. pretty straightforward…
Now analysis paralysis… to box dimensions…
just figured if the same speakers play well in both boxes… then I could probably get away with something in between
Tangent4000vsHeresy.jpg Unless you really NEED something smaller, I think it will be hard to beat the Tangent 4000, with the Super Heresy, since the box volume is much larger, you should be OK to 40 Hz. rather than 50.
Your crossover should be fine, so if it were me, I would get DaveTennessee's Super Tweeters the LMAHLs, sell the Klipsch on Ebay and enjoy superior sound with a simple tweeter swap. Otherwise you might be going backwards. I also suggest Room EQ if possible otherwise room treatments, as different house or get rid of the wife (LOL).
so what dimensions for the box?
It looks like gigantic went about 1.25 cuft larger…
Ask him. He built the box. My mod was prototyped on a Walnut (Oiled) Heresy Cabinet, purchased from another Klipschead or on Ebay. I put out a Super Heresy 1.0 and later a few more, but the original still holds. I did all the original mods on an E network, then simplified later and had people try no change in values or on the T2a Autoformer. Just capacitor refresh with same midrange, but with new tweeters and woofers AND a 4" ID x 4" Deep port near a rear corner of the removable back piece.
EVERYONE that did some form of the Mod has said WOW, and loved it. No exceptions I know of.
I lost count of the number of people who trusted in me. Grateful for that.
My Super Heresy cabinets are only slightly deeper than stock & are based off of the Crites CS2 motor boards. as such, they're 21.25 tall x 15.5 wide x 15.5 deep, compared to standard Heresy/CS2, which are 13.5" deep. The passive radiator bass bins that I'm playing around with will give the cabinets the same displacement as a Forte, +/- 1%, which I believe is the same as your Tangent 4000, or at least very close.
I've basically followed Claude's instructions for his Super H build, then added tweaks here and there out of curiosity. I began with a pair of 1971 H700 decorators, which I first restored to Heresy 1 spec. Restored, I found them as unsatisfying as before and goaded on by Claude, I modded them bit by bit, so I could fully understand what each mod brought. First, I made new back panels (I didn't want to cut up my antiques) and added a 4"x4-1/2" B-52 port from Parts-Express. The port extended the bass response significantly, however, the Klipsch K-28-K woofers really weren't up to the task: the bass response was boomy and muddy- it was a step backward in SQ, even with significantly better low end response. Next, I replaced the woofers with Eminence Delta Pro 12A's: this really tightened up the bass response and improved the midrange, considerably. They sounded great! I left them like that for a few weeks, while I contemplated replacing the tweeters. My hearing has gotten damaged from many factors: growing up on a farm, playing in bands in my teens and twenties, US Army M110A-2 Howitzers, riding and ultimately racing motorcycles and roughly 30 years in construction has left my ears with a mass roll-off at 9750 Hz. @Daveintn 's MAHL tweeters aren't cheap and I honestly didn't think they would make a significant difference, but ultimately, curiosity got the best of me and I ordered a pair. Holy cow! the sMAHLs made the single biggest difference in sound quality of any component in there. Somehow, they even made the bass frequencies clearer. these were hands down, the best sounding speakers I'd owned up until that point, although they weren't without deficiencies.
The 50+ year-old decorator cabinets were made with 5/8" birch plywood and they were "boxy" sounding to the extreme, even with foam and bracing, they had too much resonance. I also realized that I could probably flip the H700s and effectively get a new pair of Super Heresy's for free. I had a sheet of 3/4" Baltic Birch in my shop and I got to work building boxes. I ordered a pair of motor boards from Crites, as they were very reasonably priced and would save a lot of hassle with the router. I made the cabinets deeper, mainly to eliminate waste from cutting, although modeling suggested the additional 0.3 cubic feet would nominally increase low end response, I'm not entirely convinced it would be noticeable. I used K-701 & K-53 drivers because they were readily available and less expensive than the K-700/K55 combo and the rest of the parts were from the mods to the H700, although I made new networks with modifications to adapt the H-53 drivers, which were a little hotter than the K-55's. with stiffer, more robust cabinets, the Super Heresy were really, really good! I can't recommend them enough and I've encouraged quite a few people to build their own.
since then, I've been faffing about, chasing my curiosity. I picked up a single Klipsch K-361 pro speaker for a price too low to refuse, thinking I could easily flip it, only to learn why I got it so cheaply: nobody wants a single speaker. I parted it out, instead- the woofer alone covered the price I paid. I became curious about the mid horn and wondered if the bigger horn would improve the SQ, so I tried it. It did, with qualifications- the pro drivers with titanium drivers were not great, but I was encouraged enough to get another horn and try more drivers- I found a pair from PRV Audio that work quite well. Next, I wanted to tweak the crossovers to adapt the horns- the bigger horn could handle a lower x-over and driver overlap was significant; @THD+N recommended a quasi- "universal" network that would address that, so with guidance from him and some inspiration from @Deang I built one up. Significant improvement and I have the REW curves to demonstrate it! at this point, it dawned on me that my Super H clones were effectively chopped off Fortes, or not far from that and I began wondering if adding a bass bin with a passive radiator, similar to how many have gotten improved bass extension with bins on LaScalas, would improve low end response. A little math simulations showed that a 15-1/2" x 15-1/2" x 15-1/2" cabinet, added to the bottom of my Super H clones, would create the same internal volume as a Forte, within a percentage or two- while ports would be inexpensive (your Tangent 4000's) a 12" passive radiator would fit easily (Forte1) and 15" radiators could just be shoehorned in. I had settled on 12" passives when I found a pair of open box 15" radiators for roughly the same price, so I got them, knowing that I could also use them on a future project that I've been sketching out with assistance from @ClaudeJ1 and @Daveintn. (that will get its own thread when it happens). So I made a pair of extension cabinets with scraps from my woodshop. This weekend, I'll cut the bottoms out of my Super H clones and connect the two- it remains to be seen whether it would actually work, so I can't at this point, recommend the mods. I would go so far as to not recommend them until they've been tuned and measured.
If I were in your shoes, I'd simply replicate the Tangent 4000 boxes and put your Klipsch parts in them. Then, I'd replace the tweeters with L-MAHLs and perhaps replace the woofers with any of the drivers that have been successfully used in the Super Heresy Mods. While your tangents are a good third larger than Heresy's, as Claude's photo above demonstrates, they take up roughly the same amount of floor space and once could easily make the argument for WAF that there is little difference in the space they occupy, while there should be significant improvement in SQ. While Super Heresy are incredible, I'd imagine a Super Tangent 4K would be even more Super. You should do that.
As mentioned on the other forum, I would personally build them as the T-4000 using better wood....either Baltic Birch (my preference) or veneered MDF. They take up no more space, footprint wise, than the Heresy, the mid/tweeters are already closer to ear level versus tilting them up, and you already have the exact parts to make them work great. Just my $.02.
Thanks for your service. My dad was Army Special Forces Green Beret in Vietnam and my grandfather an Army rifleman/sniper in WWII.
Depending on your listening habits and your music (for me, 70's, 80's, 90's classic rock and some classical composers are my favs), I have found that using a preamp (if you have separates) or a decent 2 channel receiver with a good loudness circuit can really enhance the low end on the Super Heresy mod. You can also seek out super cheap EQ's from the 80's that were/are very good as far as construction/sound quality such as ones made by Technics. Most were made in Japan back then. If you buy one, they'll more than likely just need a little TLC with some Caig spray lubricant in the sliders.
With a little EQ, the Super Heresy mod will shine. Even at very low volumes, the fullness of the bass extension is apparent. The low frequency extension is very lifelike and natural. It is quite amazing.
Whether you are into analog or digital amps, a little EQ can go a long way.
THD+ told me about this Technics Equalizer. I bought it several months ago. I have a speaker project and I finally used it yesterday. Believe it or not this is my first equalizer. Lot of fun to use!
EQ can solve a number of problems and old but good ones are cheap. I have to admit that the EQ on DSP's like the Xilica allow for much finer adjustments I doubt many of us really need that precision.
Never expected so much love for the red headed step child in the Klipsch lineup!!!!
I was thankful for Klipsch making a budget line for us in the service and was lucky enough to be in Germany when the military was down sizing and many of my stereo parts were purchased at Steep discounts…
I always thought that the speakers were awesome at normal listening levels-and everyone was amazed with how well they played when cranked to barracks stereo war level with some Metal was so popular in that time…
I had a set of cassette, Polk bookshelf speakers, EQ along with a dynamic range expander, a timer that were lost in the movement back stateside…
Now you’re making me rethink my plans…
I am running
Onkyo M-504/P-304 amp/preamp 165W RMS per channel… so I guess I am in overkill for the power department… but I am pretty conservative on the volume…
But love the Klipsch sound especially with certain blues and folk/singer songwriter type music… But also love how it can jam from the who, Jethro tull, Metallica, yet make le vie en rose by either Edith Piaf or Louis Armstrong sound amazing…
In retrospect, I wish I'd been hip to Klipsch when I was in Germany; I ended up with a pair of Infinity SM-120 from AAFES, which were far better than the Cerwin Vega D-9's that everyone else in the barracks had, but not Tangents...
