Tannoy to play with.
krimney
Was in my local "used shop" on the weekend and noticed the price was reduced on the single Tannoy CPA-15 they had had for months.
After doing some research I decided to buy it. As they could not test it in store due to not having a "speakon" cable, I have a week or so to return it if it doesn't work.
Apparently it has the 3836 driver in it which is used in the DMT models.
Pics later.
tannoy info
Here are some specs for the CPA-15
15 inch PcQ Point Source Dual Concentric Drive units
HF waveguide for ideal spherical high frequency wavefront
User replaceable self-centering high frequency diaphragm
HF coil wound with ectangular section copper-clad aluminum wire
LF coil wound with rectangular section copper wire
Vented die-cast drive units chassis increases heat dissipation and power handling
Fatigue free sound
Thiel/Small Parameters
Model No. 3836
Vas, volume equivalent compliance 430 litres
Fs, free air resonance 27.4 Hz
Qt, total Q-factor 0.427
Qa, mechanical & acoustic Q 2.1
Qe, electrical Q 0.537
Re, voice coil resistance 5.5
Sensitivity (@2.83V, 1m, 20C) 94 dB
That would make a great mono system if given proper amplification.
Also, I don't think I've ever heard of a "speakon" before. :p:
Get a mate for it and you will have a pair of the most over-blown, over-priced speakers ever made. I've wanted a pair for years.
