ev13wt
I guess this is the correct term?
I have noticed this several times now recording and playing back a couple days later on my r2r. Basically I hear a quiet copy of the start of a track a revolution before it should actually start. It is about 40dB below the signal. (guessing db number here) It's definitely noticeable.
How can I lessen this effect? Am I recording too "hot"? Search says I should use "archive tape"?
Or is this just a fact of tape and I need to deal with it?
Second question: The RS-1506 has very wonky meters. They show input and output levels on the same meter. When recording, I set the highest level to around zero dB while turning down the output completely. Thing is, the noise floor here is still pretty high. I can crank up the levels until they are way in the red without even getting close to distortion.
I am trying to figure out how to set this thing "properly". I do have a average/peak meter unit I could place in line with the deck to show me proper levels. Is there a setting that is "proper" for tape, or do I just "wing it" every time?
I get great recordings, but I want to learn the "proper" level setting way. All my prerecorded tape has more signal to tape hiss levels.
