Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I have had a Sony TC-377 since 1975, a very good mid-priced unit. Yours was probably the entry level model in the line. Does yours say Superscope with it? That would be a clue to its age. I believe Superscope models first appeared in 1964. It is interesting that the term "tape recorder" on the head cover was misspelled by the manufacturer. Mine says "tapecorder" too.
I believe the Superscope name first appeared in the early to mid 60's on Sony R2R's. I have a tc-560 from 1968 and it says Superscope on it. If I was to take a guess I would say the tc-230 came out in either 67' or 68' ?? I know the tc-666D is from 68'.
Superscope was a USA company that had rights to sell Sony tape recorders in the USA in the 60's and 70's. Superscope used to be listed on the OTC stock exchange.
Although this deck is the bottom of the line, it is capable of very good performance. It has rubber idler wheels inside to drive the transport, that may be worn out. Try it and see if the reels move when you turn the lever to "play." You have to put a tape on it, or hold the tape sensor wire (under the head cover) to make it think there is a tape in it. If the idler's are bad, Terry Witt rebuilds them.
My father bought a TC-230 while he was overseas and I used it for a number of years while in Jr high and high school. It was a very nice unit which I thoroughly enjoyed.
I unpacked it last Christmas and it wouldn't operate due to the lubrication having dried up. This prevented the pinchroller from engaging. I have since purchased a drive belt replacement kit, and refurbishing guide from Vintage Electronics. One advantage of their belt kit is that they provide a small belt to go around one of the spools to compensate for the smaller size of the main belt. This had to be done since the stock size belt is no longer made by anyone. I didn't know this until I received the kit from V.E. which provided a note with this info. That would explain why the first replacement belt that I installed while in high school didn't quite fit.
