I would appreciate suggestions on how to adjust the motion of the idler wheel and improve its contact with the stepped speed adjustment pulley.
I was wrapping up maintenance on my recent TD-124 purchase and looking forward to installing it in its restored plinth. During testing, I noticed that the idler wheel did not contact the 16 rpm pulley at all. I'm likely ever to play a 16 rpm record, but if it's not contacting the 16 rpm pulley it's probably not doing what it had ought to be doing with the other speeds.
This is the view from above:
Moving the idler wheel by hand, I could feel that the arm carrying the idler wheel was contacting the chassis:
It occurs to me that issue might be with the spring regulating the motion of the arm:
I surely don't want it to be with Adjustable Link. That wouldn't have changed since assembly. It also seems impossible to move - I tried to loosen the screws and the heads started to deform - they don't want to come out!
Can an expert please enlighten me on what I need to do to make this right? What do I need to do to relieve the contact between arm and chassis and connect the idler wheel with the 16 rpm step on the pulley? Thank you so much!
Bob C
Bob C
