cmcguire
Just rebuilt the motor on my latest TD 124 mk2 project (this is the fifth motor I've worked on) and it's running VERY hot. Like so hot I can smell it. Like so hot a small drop of water will sizzle and evaporate on the side of the casing. This is after about fifteen minutes of run time. It's never stopped functioning but I'm afraid to let it run much longer than an hour. I've done the following:
- heat cleaned bushings and reimpregnated with sae 20, "4 in 1" brand electric motor oil
- used same thrust plate but flipped it over
-ensured original ball bearing was in good condition and in place (used a bit of grease to keep it in place during re assembly)
-lightly polished both sides of shaft
A note on the current wiring of my turntable: I've temporarily bypassed the resistor/neon lamp as it was burned out when I received this unit. The switch is still in use and functions well.
The motor is dead quiet and I get spin down times of about 25 seconds with the belt off and pulley installed.
I've completely disassembled and reassembled three times with the same result. The previous four motors I've worked on were not even close to this hot.
Any ideas would be appreciated.
