PR Audio
First, I want to thank all of you who in one form or the other took time to explain some concepts. Your help was very valuable, as to do this properly, I'm sure that there still some things that could have been better, but for a first amp project, IMHO, it looks pretty good...:thmbsp:
The amp is a Sure AA-AB32189 TDA7498 100WPC @ 6 Ohms Board (aprox. 80 WPC @ 8 Ohms). Power supply is a regulated 36 VDC unit, hookup wire is 300V rated 20AWG (doubled up at some points), the enclosure is a 10" x 12" x 3" from Hammond with cover (not shown), connectors are from PE and Mouser, and PCB feet are from EBay. I am lucky enough to have Home Depot only 3 mins. from my house, and they had all the M3 and M4 screws, nylon standoffs/separators, drill bits, and other misc. screws needed for the project. I avoided using sheet metal screws as much as possible, except for the IEC connector, enclosure feet (have not arrived yet, but on their way), and top cover.
Fabrication and assembly took some 20 hours, but mostly due to it being my first amp project, this type of project should only take 6-8 hours to complete.
When it came to wire length I didn't follow the rule of measuring twice, like I did when marking where to drill for the different components and their location. So, though it will not affect the amp's operation, the inside power cables will not follow the contour of the enclosure, like I pretended it to.
I'm not going to bore you with details, if you have any questions regarding the build just ask. Here are the pictures...
Too many meetings tomorrow, and Friday going with my wife and kid to the beach condo for the long Memorial Weekend. Will have to wait 'Till Tuesday.
