tom3
Anyone know what I can do
They only way to engage my record light is if I press and hold the record button then while I do that lift the pinch roller. The lift comes on.. but once I let the pinch roller down the lift comes off.. this is with the front plate removed exposing the electronics
This is the way it's supposed to work. When you hold the buttons and hit play, the mechanism goes up and closes the record switch the same as when you lift the pinch roller. If it's not working you might need to clean and lube the mechanism, or maybe adjust the switch a bit. The good thing is that the electronics are working.
