Teac A-450 L Channel Very Low or Out
johnnyribcag
Hi there forum!
The other day I picked up a Teac A-450 for 25 bucks on craigslist. I wasn't expecting much, but under some dust it looked pretty clean in the pics. When I picked it up, the guy told me he thought a channel was out, but that other than that it worked.
Got her home and tonight I cracked her open, checked out the belts and such, did some cleaning, etc. It was remarkably clean inside and out. The belts look a little loose and wobbly (it won't rewind, but tries, so I assume it's loose belts) but I'm sure I can replace those pretty easily - seems like an easy piece of gear to work on, at least on a basic level.
So here's my problem: when I first hooked it up to test, I thought the guy just didn't know what he was talking about - both channels were coming through loud and proud and it sounded great. However, after maybe about 10 minutes of playing I noticed the left channel fading. Eventually it faded basically to nothing.
I didn't find anything particularly helpful in the service manual, but maybe I'm overlooking something.
Googling the problem I found a thread somewhere else talking about a similar issue on a similar deck, and someone suggested maybe it was the play/record switch that needed toggled a few times. I tried that, and for a second the channel came back, but then was gone again.
I let the deck completely cool off (thinking it was a temp thing), but when I fired it back up the left channel was dead.
Anyone have any advice or ever run into this problem before? I didn't see anything like specific left / right cards or circuits in the service manual like I would expect in an amp or something (I'm new to messing with tape decks). I was pretty good with electronics in the navy, but I lack a lot of tools these days, and I'm also rusty as heck. Any help would be appreciated, I'd hate to pay someone 150 bucks or something to fix it - just doesn't seem worth it but I'd like to get her up and running.
Have the deck. Experienced the same until I cleaned and lubricated all the button and sliders with various Deoxit products. These older decks are dirtier than you think and the switches and sliders become oxidized. Once these were cleaned and toggled 30-50 times each to work the lubricant and cleaner into the switches and sliders. Fixed my channel fall out issues completely. Good luck. This is a fun deck to operate and a pleasure to listen to and easy to service.
Clean the record playback switch. It is located under the tape holders on the right side of the deck. Loosen the screws lift it up and you
will see the long slender plunger device that triggers the deck from playback to record. Deox that switch.
So far I haven't been able to get that channel working. I cleaned every switch and fader I could find inside and out. However, I didn't find that record playback switch last time. I'll look again today and see if I can find it, and let you know.
