Hello,
I've got a Teac AH380 amplifier (made in 2008) which has a problem with DC offset. On startup it is over 1 volt in both channels, but some sort of feedback corrects it to a few tens of millivolts after a minute or so. I think that this affects the sound of the amplifier, and it surely causes a "thump" in the speakers when the output relay is energized by the "thump" suppression timer. The same thing happens with both channels.
I've changed all the dubious caps to reputable Panasonic and Nichicon ones, and I've also changed the diff amp transistors to a well-matched pair. Moreover, I've checked that the supply rails for the amplifiers rise up quickly. Do you have any ideas where I should look next? I've attached the schematic to this message. Any help is greatly appreciated.
- Jussi
- Jussi
