Sebastian A.
I received this turntable today and I was surprised at the flimsy build quality of the headshell. The cartridge itself is secondary, I wasn't going to leave the AT95 that comes with it, I have an AT440MLb that I was going to put in it, except that when I put the headshell in to test it, it was evident that it is at an angle. It's not too bad, maybe 3 degrees or so at the most, but it's evident to the eye and measuring on both sides makes it clear that it's at an angle, therefore the stylus is not falling on the record perfectly perpendicular as it should, and would probably wear it in an uneven way.
The interesting thing is that I can actually rotate the headshell in its place, and make it a little more even, but not completely so. In my other turntable, the Audio Technica AT-LP120-USB, that doesn't happen. While I haven't measured it, it's not evident to the eye that it's anything but perfectly straight, and if I try to rotate the headshell it barely moves and it always ends up in the same position. With the Teac, I can actually change the rotation of the headshell because the construction is mediocre.
This doesn't seem to affect the sound quality, I tried a few records and even with the AT95 it sounds pretty good, and I can't really tell if there's one channel that sounds louder than the other if that's the case. However, the fact that the stylus is not touching the groove perfectly even makes me concerned for my records.
Now, even if the retailer pays for the shipping back and sends me a new one, it's a pain to pack it, take it to a UPS Store, and then who knows if the replacement will have the perfect angle. So I don't want to get a replacement that I will have to unpack, and then pack again and take to the store.
Did anybody else who owns this turntable notice this? Or did I get a lemon?
