Wigwam Jones
Caesar non supra grammati
First, I decided to take the plunge and try to replace my drive belt on my Teac V-1RX. I bought it new in Okinawa, Japan, in 1983. I'd like to put it back in service.
I got the top off. I had an earlier thread there I noted that the cassette door was 'locked' and I could not get it open. Someone told me how to revolve the top pulley until it unlocked, which I did, and it opened. Yay.
Now, after some time, I finally had a spare moment so I put it on the table and opened it up again. I saw the old belt had simply stretched. And by peering closely inside the deck, I saw I could remove it without actually removing any part of the drive. So far, so good.
Since I have not yet ordered a belt, I looked around and found a rubber band. Yes, I know, this is not a suitable replacement, but I just wanted to see if it would go around. It does.
However, when I power the deck on, the big pulley on top rotates, going 'click, click, click, click,' etc. The door locks and won't open again. None of the functions work. I put a cassette in and pressed play and the heads started going up and down, up and down, up and down, and the big pulley was going around going click, click, click. I powered it off, rotated the big pulley around again until I could unlock the door, and took the tape out.
So...two questions.
The first is, what the heck is going on here?
The second is, where should I order a new drive belt? I looked in the old threads, but the comments that I could find date back to 2005 and a lot of dead links. So if you have a company that you've dealt with recently that's still in business, please feel free to recommend them.
Thanks!
So...two questions.
Thanks!
