Teac V-95RX -- No Left Channel Output
SSowner
This is only my second post on AK, I mostly read everyone's posts to solve issues with my audio gear. Thank you everyone! I have researched for a couple of days for ideas on how to repair a V-95rx I own. It has no left channel output at the RCA jacks or the Phone jack. Any ideas would be appreciated. What I have done so far:
1. Downloaded Service manual
2. Checked "Output" Pot -Good < 5ohms between RCA output and Point 32 on R/P circuit board
3. Removed Cleaned/polished the Solenoid actuated slide switches S101 and S102 (FWD /REV and RP and reinstalled same.
4. Flipped P1(from Head) on R/P circuit board-- problem did not follow, still no left channel. Normaled up P1.
Thanks ahead of time!
You would need a scope to follow the signal from the heads to the outputs.
If you have both channels on the meters, it could narrow the search area.
Thanks hdrobien-- No display on left channel meter even after flipping P1 (swapping L&R input to R/P CC from head). I will try and borrow a scope. Anyone else? Checked TP L and TP R with tape playing, both show ca 380-390mv.
Ok, so you need to find the service manual and follow the circuit from the TP to the output.
S104/S105 may be guilty.
Thanks for the input. Sorry for the late reply. Have not tested either yet. S101 and 102 were not too bad though. We'll see. Thanks Again
These things can be a pain to work on but the solenoid switches can be a very big problem in that spray cleaning may not be enough. This is why I use Curt Jacobs retrofit switch for the X2000R where it has a like type switch that is also unreliable. I have repaired this in the past both at my own shop and some at Teac when I was there in the 80's.
The V-909RX was an improved model of the same kind of device with 4 channel heads but out of the decks that I approve of that were auto reverse the R-888X was the one that was much much better in design with a three head rotating function but that the stops were ceramic that held good alignment. 4 channel heads rarely were in good alignment in both directions- I got one to do it in 3 hours work but it was done in adjusting the tape path run to do it. The $14 4 channel head was not all that precise of a device or part.
You don't need to reverse plugs and that. The lack of signal through a channel can be done using the buzz test as in touching the head connector with a screw driver and seeing if output is at any amps after that. It is good to keep an eye out of 10V caps of the Marcon type as I have seen them fail in many types of equipment including NAD and Teac . I pulley 16 out of the Tascam 48 when some of them shorted- they were 220uFd 16V types but Marcon again.
Thanks for the replies Sam! I disassembled and polished the contacts in both solenoid switches. They were not too bad, black and gray in spots but shiny where the contacts met. I will try the buzz test and check those caps. With the holidays i will be pulled away from the work bench often, I end up starting from the beginning every time. LoL. During my Electronic Maintenances time in the 80s(Army) I would do binary searches, test the circuit halfway through-- Bad reading problem was in first half, good reading problem in the send half. Is there a half way point with the v-95?
I'm assuming you have tried all the noise reduction modes, none/dolby/dbx, and none make a difference.
Any chance Q103 is shorted? What happens if you float the collector on it?
Don't know if it's same issue, but i am able to get back sound on all channels when playing with output volume and/or the type selection (norm/cr2/metal). I guess in my case i need to deoxit these contacts
