Technical note: 6CG7/6FQ7 tubes and heater voltages
GordonW
Speakerfixer
From my work on my 10-5 project amp, I noticed one idiosycrasy about the 6CG7 tube.
These tubes DO NOT like lower-than-spec heater voltage!
Bringing the amp up on the variac, I had WILD variation in transconductance (as shown by differences in bias current with the same B+ and cathode-bias resistors on both sides) between the two sides, under low voltage.
HOWEVER- once the voltage was set at normal (with, naturally, normal 6.3v heater voltage), both sides were almost EXACT match, as the tube showed in the tube tester.
I checked several 6CG7/6FQ7 tubes (RCA, GE, etc)... and they all exhibited the same behavior!
So... if you ever have a balance problem between the two halves of a 6CG7/6FQ7 tube, be sure and check the heater voltage at the socket where it's installed!
Thanks for the tip GordonW. I'm using 6CG7's as drivers in one of my homebrew amps. Good info to know.
David
