On most carts it is hard to beat the 52mm square in the HS alignment
Ok. I'm confused...
Does it measure the 15mm from the front of the spindle ?
Originally Posted by Rob.
Ok. I'm confused...
Buy one of these. I think I paid $4.95 for mine including shipping. Place headshell and cartridge in gauge and adjust so stylus is even with end of gauge. Align cartridge so it is square. Done. Finished. That's it.
The protractors are for turntables that do not have S-Shaped arms.
This method, you are still eyeballing it, so it's not 100% exactly centered or lined up !
Sometimes a novice just doesn't know enough to understand the answer. I've been there.
Frank Sol is frustrated... Not only with this thread but others when...
Someone asks a question then when given a consensus answer by long time posters the questioner wants to argue with the answerers as if the questioner knows the only correct answer :thumbsdn:
Why even solicit answers ???
12ax7, I assume you meant no, it isn't measured from the front, it's taken from the centre of the spindle.
