Technics 1506 question
jdwk
AK Subscriber
What is the size ( and name) of the type of washer that goes in the larger hole around the side panel screws on a 1506? and anyone know the size of the side panel screws themselves? I just got a decent pair of side panels for one that had been rack mounted and am trying to put it back to original. thanks! These washers are found in other vintage equipment that have wood side panels, I just do not know the proper name so they can be searched online.
I'm not familiar with the RS-1506 but service manuals typically ID the hardware used. They usually indicate the screw size and length, like M4 x 30mm. Side panel hardware can be flange washers, countersunk cup, shouldered washers, etc.
Ebay sellers may offer used OEM side panel hardware. Sometimes manufacturers use plastic washers and custom size large heads on screws you can't find in aftermarket hardware.
This is some of the side panel OEM hardware I've encountered and what I've used with custom hardwood sides. In aftermarket hardware, I try and find the largest head size available and a countersunk washer the head will just fit in. Typically, the shouldered washer ends up being an M5 used with an M4 screw. While the hole is too large for the screw, the head fits the countersink. Next to last pic compares OEM with what I could find aftermarket on some custom hardwood sides. Last pic is chart of M2 to M8 from one alloy countersunk washer manufacturer.
