Synchro-bias
New ClassA
I was going over changing my diy silver cable, to Mogami 2965, as it has good capacitance. I dont know if it will sound better, but the Mogami seemed to go with with my other Technics turntable. I did consider Van Den Huls Flexicon B4, but not much about it online.
With my D212, i was able some time back get on a good buy Van Den Hul SPC tonearm wire and headshell leads. Its a rough looking table. However the previous owners had it professionally restored, and I got 2 custom lids with it, i settled on the frosted on.
Upon fitting the cable today, i thought since the elec caps were exposed i would look at them under light, and to me it looked like some stuff on the pins, i de-soldered one cap to check as per photo.
I am reluctant to recap, due to the worry it could affect the operation #-o , and i dont have a capacitance meter to check the capacitance. If i had to, Nichicon PW series maybe or Pano FM FR etc. The caps are leaking something, which isnt good
The pcb board has the IC AN66 something and 2 trimpots, some elec caps, etc
So i checked my other Technics turntable SL-5210 and the same thing, a few caps with greenish legs, some of it actually on the board.
Operation of both turntables including the D2, is somethings when place the arm on the record it would lift up and return and stop, and other times the arm would life up and down, this was fixed by spinning the platter when the turntable was off. The auto return is playing up on the 5210. Could this be because of the caps?
As for the D2, to get to the board? it looks like there is quite some work? whereas the other turntables it was easy access. I assume the D2 would have a few caps leaking also
