Technics/Panasonic MASH CD Players
Arthur Smith
When I sold consumer electronics in the late 80's/early 90's, we avoided selling these like the plague, as the commissions, dictated by Gross Margin, was so low. Now, after rediscovering the Technics/Panasonic line through thrift purchases, I am discovering that these products were quite good, and some of them were great. I picked up a basic entry level CD player with that awful "MASH" acronym. Now, after listening to it last night, to my ears, it does have a rather warm, detailed sound. Without getting deep into the weeds specific to pseudo digital technical jargon, was this what they were trying to achieve with this technology? And, would a difference be at all noticeable on most systems?
As was often the case with manufacturers that didn't sell a lot of bling, there's loads of hearsay idiocy that caused these effects. "Oh, it says 'Technics' instead of 'McIntosh', so it must suck, especially since I've never heard 'MASH'."
Well, I could bet as much money as I had that nobody would be able to distinguish any off-the-shelf CD player from the late 80s or later in terms of sound quality. Those stories are just based on emotional autosuggestions.
Back to MASH itself: the acronym is only "awful" in that it doesn't match very well what it's supposed to say: "Multi-Stage Noise Shaping." W.pedia can tell more about what noise shaping is.
In the end, MASH chips were basically four bit DACs that didn't sound better or worse than any other decent converters from, say, Burr Brown or so. They were developed by Matsushita (now Panasonic), extensively used in Technics CD players and found further usage in Sansui and NAD devices, as well as—obviously—Panasonic professional gear.
If it is about CD players there's nothing wrong with one having a MASH chip. There are many other important criteria for choosing a CD player: visual appeal, build quality, features, access times, gapless support, etc. In this respect Technics CD players (at least the later ones from 1989 onwards) are pretty recommendable, as they e.g. use extremely fast linear magnetic CD mechanisms that allow TOC readings and track jumps in ≤1 second; the TOTL models also have many nice features (jog wheel, 20 block access keyboard, etc.). However, it still has to be said that those specific models were mostly released before the MASH era, e.g. the SL-P770. However, if you want one with all of that and a MASH chip: go for the SL-P777. The front says "4DAC 18Bit", but inside they secretly employ a MASH DAC. Apparently Matsushita was not sure whether people would take it well that they now had a 4 bit chip instead of four 16 bit* ones.
*This is not a misprint: Technics used 16 bit converters but employed a pair per channel and slightly shifted one of them using a Yamaha multiplexer chip so that the total construct factually worked with 18 bits.
The build quality on these Technics players was horrible- cheap looking, cheap feeling plastic. Amazingly, they seem to have endured and lasted. I see tons of them out there "in the wild", and if the one I bought is any indication, they work and sound great. Just be prepared to cringe when you touch that chintzy plastic panel and buttons.
Really? At a combined weight of 88 pounds the Technics SL-Z1000/SH-X1000 CD Transport and MASH DAC combo player would beg to differ!
The build quality on these Technics players was horrible- cheap looking, cheap feeling plastic. (…) Just be prepared to cringe when you touch that chintzy plastic panel and buttons.
So, tell me, which models are these statements referring to? From my experience, they apply only to the absolute bottom of the line models, and actually not even there. Extrapolating from this is like saying that all Ford cars are bad, because the Pinto exploded when rear-ended*.
*forgive the analogy, but I couldn't come up with a better one. You'll get the idea though, I suppose.
I like Technics as a brand. Just that when they went to the brown plastic designs, the materials they used on the front panels got cheaper and cheaper feeling.
This reminds me I need to finish my tube converted SL-P555 from 1989. This "secretly" employs the first generation MASH chip (MN6471). It's a Japanese 100V model, and has a nice aluminum front panel unlike the rest of the world which used plastic...
I've honestly never seen the point in implanting 1940s technology (tubes) into a CD player like this. The characteristics of these players are excellent (see a post here [sorry, in German] on the SL-P999), so why ruin them in such a way? Why not create an external tube preamp instead?
We are just bypassing the buffer stages which are based on some generic Op amps. The output of the MASH chip is high enough that these are not needed. Having an external tube buffer would imply longer cable lengths and connections. This is a very simple stage using a 6CG7 per Lampizator's recommendation. Doesn't hurt anything and can actually be beneficial, sonic-wise.
This particular unit is pretty much finished. I just need to create an analog domain pre-emphasis network triggered by the dedicated transistor in the player itself when a disc with emphasis is being played.
Technics SL-PG490
Nice operation of the draw and controls, quiet mech, very light thin metalwork, quality paint and exacting fit. Some fairly sharp edges inside.
This is one from an auction site after recapping, sorry no pic beforehand, note drive is upside down in the photo showing the dac and replacement caps are much bigger at 35v. The main PCB is divided between power and audio, it's very prone to track lift when resoldering.
Two stages of coupling caps dac to opamp and opamp to line on this one. Very tiny capacitors, the coupling caps to line are just 6.8v 47uf but read ok for ESR. All caps are bare minimum for voltage not necessarily a bad thing with quality caps.
The yellow tubes next to the transformer are Vishay 1813 film capacitors at 3.3uf, which replace the tiny electrolytic caps, its a tweak for improved sound quality.
Overall highly engineered but cheap, the feet at the back are just depressions stamped into the case rather than separate feet.
I have several of the players from the Matsuhita consortium - 5 Technics and a Teac, and I try to only grab those with the MASH system. Most have Teac-based transports and are pretty straightforward. The DAC philosophy seems to work well for SQ. I also have some Panasonic, Sony, Sharp, Marantz, and Pioneer players, but the MASH seems to work well.
I'm big fan of Technics CD players, from the early SL-P8 and 1200, to the 770, 777 and 999 (all of which I own examples of). I'll concur the MASH era units sound great, but even the pre-MASH equipped units sound good (enough) to me. Interesting too that Matsuhita's own in-house developed optical blocks have had a very good reputation for longevity, even in the earlier models from 1984-86.
Where many of the competitors during the first two generations of players used the Toshiba/Olympus TAOHS pickup (which has proven to have a very high failure rate, though admittedly some 40 years on now) many of the earliest Technics players are still playing reliably, with a few (as my own collection) still in regular use. I like them a lot. I also have a few mid-lateish 90's players by Sansui that are MASH equipped, and are really very good, if fairly obscure and difficult to find in the US.
Many of the pre-MASH Technics players were built like tanks, and had Burr Brown DACS, they sound sublime. Keep the MASH players, I'll take these.
As I said, I like both eras of Technics players. The build quality was better pre 1990, no doubt. I just chuckle at those who look down their nose at Technics. Were they mass market gear? Yes, of course they were. But much of their production was really quite decent, and their very best stuff was excellent.
What's not to like about the late 80's Technics players? I have SL-P120, 520, and 720 here (late 80's) as well as a couple of SL-PS50 players. Here's a picture I took of the 520 and PS50 in one of my systems.
Both great players, though I prefer the x20 series, especially the 720 and 520 with the search wheel and the small window over the tray to watch the disk spin! :beatnik: PS50, 720, and 520 all have electronic volume control, but the x20 models have a column of lights on the right side of the display that decreases as volume is decreased. A really nice feature to let you know visually where the volume on the player is at. The x20 players have a BurBrown DAC and are very well built and heavy. Even the lowly 120 has decent weight to it.
