Technics Professional Series rack system
HFFHBlast
Good afternoon, guys. I've been putting together a Technics rack system incorporating the Technics Professional Series w/ three (3) SH-999 racks (hard to come by, for sure), but including other gear that I think they should have included (cassette deck, audio timer, reel to reel, second amp, etc.). Two questions I'm hoping you more knowledgeable folks might have insight on.
1) The Pro Series was advertised with 3 options of turntable. Mine has the SL-1500 with a curiously painted RED lower stage on the plinth. Anybody know what this red paint delineates, or was this a special edition of some sort? The real question here is ... it came w/o cartridge or stylus. Is there a brand/model of cartridge that came standard with this turntable? Lacking an answer to that, can someone that is proficient in this area recommend a high quality replacement that would make this turntable shine (audibly)?
2) I've owned many R2Rs over the years, and have read about specific types of recording tape that are recommended for different machines. The Technics RS-1500 is a terrific deck, and I've had relatively good luck with high bias- type two, Maxell, Scotch 226, and others. My hope is to understand the criteria that makes one brand/model/bias work better (as in, "This machine is set up for TDK 724 High bias, recording tape)". I don't believe this is just a company showing preference for advertising purposes like we see today on far too many products.
I'd like to set this system up to factory recommended status, to achieve the best sound possible. They designed and built this equipment, and I assume they had a great deal of failures and successes in drawing the best possible sound reproduction from their gear before offering it for sale... their reputation and future sales being considered and all. Any input you can give towards this will be highly appreciated, fellas. Thank you much.
TK
It is recommended to set up a tape deck for the tape you are going to use. When I got my Tandberg, the store was selling Maxell. I bought a case of reels and brought the deck and a tape in for our tech to set the machine up for that tape. Sounded great, made great tapes.
Today there are a few different tape manufacturers and tape can be better than the Maxell. I'd recommend setting up your machine, have a tech set the bias for a tape you decide to use. But most don't go for new tape and you have said you like Maxell so maybe have the machine set up for either the UD35-180 or UD35-180B, the back-coated tape. They are close but there may be a difference. I don't know if you would hear much difference setting it up for one of those and using the other.
My Tandberg has no bias options on the front panel it is tech adjustments only. If you have switches that can be set individually, maybe find out what tapes will use one setting and what tapes use the other setting(s) and have the machine set up for a tape you like in each group.
Could have sworn I left a response, gratitude for your response. You're right on the subtlety or any audible difference in sound quality between and 'recommended' magnetic tape, and other high quality recording tape.
I have better ears than most folks, but always hoping to get the maximum quality recordings possible, 'by hook or crook' as my pops used to say.
At 62, I'm just getting into DACs, and somewhat dreading getting into this tech so late. Too many choices, really, but holding to a budget surely shortens up the list a bit. Anyway, best of luck to you, hopefully catch you elsewhere on site here.
TK
