PoPSiCLe
So... I know a little bit about measuring and fault-finding, but I am still a novice, so bear with me.
Symptoms as follows: Everything seems to work - level meters, level adjustment for recording, selector switches, buttons - everything works, clicks etc.
However, when I hit "record" nothing happens. It has a light that is supposed to turn on when recording, this does not turn on. If I go to tape-monitor, it plays what is already on the tape - ie, no erasing what is on there, and no recording of new content.
It has a record mute button - this works (tested continuity while pressed and not) - has no effect on the actual recording (it still doesn't work) - I was hoping this button might've been stuck, but it doesn't seem this is the culprit.
All other functions work fine, play, ff/rew, etc. After looking through the service manual, I found a few test points, which (if I read the manual correctly), should give some voltages when measured. They do not. It is flat at 0, which I assume means they do not get power at all. But that is kinda where my knowledge of reading schematics and such end.
Anyone able to take a look at the service manual, and maybe suggest some things / places I can test measure, to see if I can pinpoint where the problem occurs? Looking at the board / components, I can't see any indicators of anything wrong - caps look good, everything else look good, no burnmarks, nothing.
Nothing gets overly hot either, while it is turned on, so no obvious shorts, it seems.
Service Manual:
https://cdn.discordapp.com/attachments/1045368361657319565/1045368361950924830/technics_rs-m260.pdf
So, I was hoping someone could point me to some things I can test, measure, etc. Note that I while I do have an oscilloscope, I've never played with it, and know next to nothing about it, so preferably stuff I can do with a multimeter.
Service Manual:
