Adippell
Hello Ak’ers,
Ok, so this is my first thread, aside from the introduction so please bear with my ignorance.
I have a Technics SA-202 that I purchased at the Salvation Army for $15. It had a blown fuse on the back panel for the left channel. I replaced the fuse, but this didn’t rectify the issue. So onward to my first attempts to diagnose the problem. To start I took off top and bottom panels and de-ox’d the pots. I inspected the board and didn’t see any obvious burned or blown parts. I checked inputs (FM, AM, Phono, and Tape). There is no sound at all coming from the left channel, not even a hiss at full volume, from any inputs. I made sure the balance was centered.
So this is when I discovered AK, google searching this unit has brought me here and what a resource it has already been!
After reading through several threads, but none related to exactly to this unit, it seems the most likely issue is the power pack (STK0029). I have a fluke multimeter, so I started with the capacitors and all seem to power up and discharge. I read on a related thread to use the diode function to test the power packs. It was a thread for a SA 101, and Ak’er wd409 said “you can do a diode test on the power packs, red probe to pin 1, black to pin 10, then switch the leads to the opposite sides, then test 2 and 9 as well, and then switch it. one polarity should say OL and one should say around 0.600 give or take, the one that shows 0.000 is the dead one. assuming it has 10 pin power packs like the 303 and 404 have.”
So I started to test and didn’t get any of the readings suggested. Obviously it’s a different power pack so the values would be different. This is what I found:
The left power pack (when facing the unit) reads “OL” no matter what pin combo I used (1 & 0, or 2 & 9) and regardless of polarity. Then when powering the unit down the meter would read 1.4 using the + on 1 & - on 0.
The right pack reads 1.7 and OL respectively, then 2.62 (and OL on the other polarity) when the unit is powered down.
One other issue is when the test speaker is hooked up to the right output and the unit is powered on initially there is a loud popping sound. If the unit is turned off and then turned back on after the initial there is no popping sound. If the unit is off for approximately 5 minutes and then turned back on the pop comes back.
So my thoughts are that the left pack is bad and needs to be replaced. But before I start dismantling the heat sink and break out the soldering iron (and ordering parts from eBay) I’d like advice from those who have more experience. I have no idea what is causing the popping.
Thank you to any and all who respond to my query. I promise to follow up on any advice given and report back any results.
** Posted prior to the reset, Ak'er suggested I disconnect the left power pack and see if audio comes through on the headphone jack. I discovered that my soldering iron is DOA, and have ordered another one from Amazon. So that test will have to wait a few days. I did try the headphone jack as I hadn't thought of trying that output, same as the speaker output. No sound at all.
