francisleo75
Member
Hi,
I'm trying to bring back to life a SA5070 Technics receiver, perhaps someone of you more experienced can put some lights on.
Firstly, I couldn't find a free service manual anywhere, so please if you have a pdf can you please share with me? there is nothing in the AK Database, I have no access to hifiengine.com and everything else is paid.
It turns on, lights ok, DC offset super high: 15.9V Left and 25V Right channel, so off course no output (Not plugged the speakers). the signal indicator is bouncing so I'm assuming the FM stage is OK, and that's it.
At first glance it seems a problem in the STK043 but, I'd like to check the power supply stage (again no manual for reference ;/) .NOTE: I ordered a Chinese IC but, after installed the resistors R631 and R633 started smokes...now I don't know if this IC came out bad or not. Basically, I'm lost. Any thoughts?
here is the readings on the IC STK043:
pin 1-16 with the manual values ( * ) -- > got a print shot from other thread with these values.
1. 120mv (-30mv)
2. -9.4V (-30mv)
3. -7.2V (0)
4. -24V (-23V)
5. -24.5V (-16.9V)
6. -25.3V (-25V)
7. -16V (0)
8. 23V (24V)
9. 25.3V (25)
10.-25.3 (0)
11. -25.3 (-25)
12. -24 (-16.9V)
13. -24.3V (-23.1V)
14. 5mv (0)
15. -9.4V (-0.03V)
16. 135mv (-0.03V)
1. 120mv (-30mv)
2. -9.4V (-30mv)
3. -7.2V (0)
4. -24V (-23V)
5. -24.5V (-16.9V)
6. -25.3V (-25V)
7. -16V (0)
8. 23V (24V)
9. 25.3V (25)
10.-25.3 (0)
11. -25.3 (-25)
12. -24 (-16.9V)
13. -24.3V (-23.1V)
14. 5mv (0)
15. -9.4V (-0.03V)
16. 135mv (-0.03V)
