Technics SA 5570 problems
Moth R. Superior
Hello fellow AKer's, I just happened upon a Technics SA 5570 and I was pretty excited to hear a more powerful Technics system.
I've been using an SA 300 for some time now, and I've always been impressed with the quality of these amps. They still seem to be somewhat of a sleeper as far as comparative costs go.
I expected it to have some issues, (let's just say the price was right!) but upon my initial inspection, none of the lamps worked. I noticed the 5 amp fuses on the back, it was missing one so I replaced them both.
When I turn it on, I can tell it's getting power, I can hear the distinctive 'click' of the relay, and I can even smell the power. However, no lights, no sound what-so-ever. Not even from the headphone jack.
When I select AM or FM, the signal needle dances around, as if it's receiving some signal, but alas, no sound.
Where do I start?
Upon initial inspection, all caps seemed solid (no bulging or leaking), no obvious heat damage... (it is kinda dirty in there)
Any advice?
There's a .5 amp fuse that protects the lamps and provides the 11v half wave rectified DC for the protection relay drive transistors.
Run it connected to a CD player.
Try it with something other than the tuner.
Ran a digital out put, (my phone) through the aux and still no sound.
Find that fuse.
Replace it with the rated value. Or remove it and check for continuity.
Fire it up with a DBT
Check for a dim bulb.
A dial lamp could of blown the half amp fuse.
Well, I finally got back to this project. And it's singin'! :banana::banana: I'd always found Technics kind of a sleeper, but now, I've got some more opinions.
My introduction to Technics was via an SA-300. A completely different line as the SA-5x70. And even though i've gone up in wattage ( from 35 WPC to 85 WPC) I'm still getting better sounds from the SA-300.
The loudness button performs completely different.
Don't get me wrong, the Treb and Bass are plenty responsive, but I'm missing that "sweet-spot" that one only gets from the use of a loudness button.
Something I'd first noticed when I went from Technics to Marantz, and how much improvement even the highs got from a loudness button. (In comparison)
I have been giving my speakers a ride though!:rockon:
