technics Sa 600 no sound to speakers. Getting output to everything else !! Newbie help
mrcaps
Ive replaced the fuses on rear, cleaned the relay protect switch, inspected the 3 fuses inside visually look fine (not tested). Im getting output to headphones. Just nothing to speakers. Safety light is green, Im new to repair so any pointers would be very welcome. Many thanks.
Only difference between headphones and the speaker outputs is the speaker switches.
Make sure those are clean and you don’t have any broken traces, broken wires, etc.
Pretty easy to ohm out from the relay onward. See where it stops.
