MisterFishey said:
Browsing on eBay, I found the SA-5560. Anyone know anything about this? It's really cheap, too. Judging by the model number, it seems to be a step down from the SA-5770.
You know, you shouldn't get all hung up on the Technics brand, as the
only choice for a new to you vintage receiver. Especially with the budget you have onhand. There's literally tons of possibilities to choose from, but much will depend on your ability to be patient, ramp up your knowledge via the web to understand each individual receiver's inherent abilities better. In fact, imho I recommend you be Open Minded about this, explore and learn for a time, while you nose around the marketplace to get a better feel of what values really are.
Anyone here can recommend some fine receivers from a wide selection of Brands/Makers. If you want a bargain, (and who doesn't, right), you will need to look at some Brands that are more off the radar, so to speak. And in that mode of thinking, I will step forward with an alternative likely lower budget/big bang for the buck choice...something like this>>
http://cgi.ebay.com/Nikko-NR-1415-A...43QQihZ010QQcategoryZ3279QQrdZ1QQcmdZViewItem
But like I said, there's literally tons of choices out there. Hopefully, others can pipe in and suggest a few more. There's LOTS of quality receivers out there. It's up to
you to figure out what is good enough for what you have in mind.
No offense intended btw, just trying to communicate in an honest way.
be well
Marko
