Technics SB-A52
GEN X
Hello all, I just recently picked up a set of Technics SB-A52 speakers and was wondering if any of you guys have any information on them. I've done some research and the only thing I can find is a manual from Mike's manuals but I have to pay for it and was wondering if one of you guys maybe had the manual. I'm looking for any and all information you guys have on these. I would love to know the frequency response on the driver's for one, as they are extremely hard to tune.
Often when there is little info available they may be rack system speakers or all in one system speakers. JMO those seem to be too large to be all in one speakers.. Another option might be overseas versions. Japan issue and sold for example which sometimes use a different model name or number from USA versions, though in this case I don't think that is the case. It appears the label says only 8 ohms and 250 watts/music.
Lots of Google hits/results with no info.
What exactly do you mean by "hard to tune"? Technics' published frequency response specs for speakers, were, shall we say, optimistic at best, so they probably wouldn't help you much.
But yeah, rack system does seem a probable source for these, especially since I checked the Audio magazine annual equipment directory archive (October issues) for Technics speakers from 84-93, and not once did I find an SB-A model listed, which indicates to me that it's likely that series was not sold separately.
I'd suggest a little more optimism. Technics was, and is, a large and very capable company, and I've encountered rack system speakers that were surprisingly convincing (and plenty that were lousy). So listening is the only way to know, especially since tastes differ. I will say that I heard a small eight inch two way Technics that looked similar and impressed me mightily. When I finally found a pair at a tag sale and took them apart to look, I was surprised to fine that they had two spiders - one in the normal location, and one somewhat up the cone. What this did, I'm not sure, but it certainly wasn't the sort of thing you would expect on a speaker designed only by bean counters.
I've gone on in other posts about the merits of a large multi driver pair of Kenwoods I refoamed out of curiousity, and I think you should listen to these with an open mind - driver specs only tell a portion of the story. Nothing replaces actual listening.
I'm unclear what you mean by hard to tune - start with all tone controls flat and see if the frequency response is relatively even and smooth. If the high end is lacking or hard, try recapping - often the electrolytics are out of spec. There are close to an infinite number of threads on recapping and what caps to use, but new electrolytics are cheapest, and will enable you to hear what the designers thought they were achieving. You can always upgrade to film caps later, if you want.
I have a pair A-50's, were a rack system speaker. I always thought they sounded decent as a starter speaker. I still keep them as a backup when my good speakers are being toyed with.
see if you can replace the caps in the crossovers with jantzen crosscaps. I replaced the 1 capacitor ( Yes, 1 capacitor only!) in my A-50's with a Jantzen crosscap and it improved the sound with that touch of the wonderful Jantzen sound signature
