TrevorBarten
Well-Known Member
I am currently working on a se-9200 power amp that really does not need that much work. I adjusted the dc offset on the speaker leads to 0.00 volts however I also wanted to adjust the bias but I couldn't really find anything about this in the service manual. I was expecting maybe a target voltage or measuring point but unless I am not looking correctly I can't seem to find any of this. Could someone tell me what I should do ? Is there a standard or can I use context clues to decide? Also another thing I noticed is that the dc voltage on each channel is not the same for the right and left speaker output. There is a difference of about 0.04 V. I couldn't really find how to adjust that either but I assume that just has to do with shifted resistor values and wasn't made to be adjustable or not?
