Technics SE-A3
vonclod
Just wondering if any members here are useing one or have owned one..it's not you typical technics and those familliar with it know that.
I'm wondering how it compares to something current, I'm guessing you would have to spend 5k and up..more likley up to get a better built amp(with new output devices anyway). Reason I bring it up is there is one freshly rebuilt available to me..not cheap but it could be the last amp I ever need to own..I believe it does the first 70w class A and a good match with my newly aquired Threshold SL10 pre.
SE-A3 Specifications
Rated minimum sine wave RMS power output 20Hz~20kHz both channels driven with 0.002% total harmonic distortion 8 ohms. 200W
Rated minimum sine wave RMS power output 20Hz~20kHz both channels driven with 0.003% total harmonic distortion 4 ohms. Note that because of impedance monitoring the 4 and 8 ohm values are always the same. 320W
1kHz continuous power output both channels driven 0.001 total harmonic distortion 8 ohms. 220W
1kHz continuous power output both channels driven 0.003 total harmonic distortion 4 ohms. 350W
Dynamic Headroom 8 ohms. 1.1dB
Dynamic Headroom 4 ohms. 1.8dB
Total harmonic distortion at rated power 20Hz~20kHz. 0.002%
Total harmonic distortion at half power 20Hz~20kHz. 0.001%
Total harmonic distortion at half power 1kHz. 0.0003%
Transient Intermodulation Distortion. unmeasurable
Frequency Response DC ~ 20kHz +0dB - 0.1dB
Frequency Response DC ~ 300kHz. +0dB - 3dB
Input Sensitivity 70mV (1V, IHF '66)
S/N (IHF A) 100dB
S/N (IHF '66) 123dB
Input Impedance 47k ohms
Low Frequency Damping Factor 8 ohms 200
Low Frequency Damping Factor 4 ohms 100
Total Load Impedance 4~16 ohms
Meter Reading Range 8 ohms 0.0001W ~ 300W
Meter Frequency Response from 10Hz~20kHz at more than -40dB +/-1dB
Meter Frequency Response from 10Hz~10kHz at less than -40dB +/-1dB
Meter Attack Time 50usec
Meter Recovery Time 750 ms (0dB to -20dB)
Power Consumption 1150W, 1400VA
Dimensions (WxHxD) 16 15/16" x 8 3/16" x 19 31/32"
Weight 32.5 kg (78.3 lbs)
a few pics
Anyone?..I know these were rare, not much info out there or reviews. There were problems with these amp due to the output devices but there is a fix.
Not class A.
But that doesn't matter.
Presumably a good amp, but I would prefer an integrated for permanent use. The less junk in the signal, so much the better. I'd never use a separate pre-amp for serious listening.
It's also a fairly late Technics, which means it most likely contains a lot of ICs of which there are no replacements available anywhere, so it's not really guaranteed to be a "for life" sort of thing. When it breaks, it's finished.
But it is cool looking, and that's the most important thing I think. :)
Not class A.
It is sweet looking:thmbsp:
I do run a Sonic Frontiers integrated that I enjoy quite a bit in the fall/winter..heats my suite:D
I agree with the concept of less in the chain but wanting to try something different and SS. Im amazed by what my Threshold is bringing to the table with my Carver M500..cant wait to try a more DC oriented amp.
Im wondering what really makes an amp class A at the end of the day? the nonexistant switching distortion is what the benefit of a class A due to no switching..lol I guess my question is what would a pure class A amp do or perform differently from the new class A.
Cheers.
