david winter
Classical music lover.
Hi,
I'm stuck on this amp. The input board has been recaped. I also changed two small electrolytics on the power stage board.
Right channel works fine, and bias adjusts without trouble.
Left channel will intermittently work well with stable bias once adjusted. However, when the problem happens again, I get 0mV accross both test points (i.e same positive voltage around 14mV) and the trimmer won't adjust anything. DC protection circuit clicks in both cases.
As a result of the problem, the test signal gets clipped on the negative side, which seems to indicate on what section of the output stage the problem happens.
I don't think it's the left section (intput board with double transistors). If I disconnect it from the output stage, the audio output becomes ok whereas the problem messes it up almost all along the audio path.
I tested all diodes (in diode mode) and supposing I did everything correctly, I didn't find any problem even in the synchro bias blocks.
The first question I wonder is whether there is any known 'crap' transistor type in this amplifier.
Output stage uses the following types:
- 2SC1845 and 2SA1015 (I doubt they're candidates)
- 2SD661
- 2SB745
- 2SC2623
- 2SA1124
I uploaded the service manual there (temp location, may be removed in the future).
Below is a partial schematic as well as the signal once in trouble...:
Any hint appreciated. Thanks & Merry XMas !
David
- 2SD661
- 2SB745
- 2SC2623
- 2SA1124
David
