Technics SL-10 bulb replacement
Erika_DV
Hi,
With the information I found here on Audiokarma I was able to completely restore a Technics SL-10 to full working condition.
What I would like to share is my solution for the bulb, that was dead.
The solution I used was to replace the bulb with a LED (5mm, 3,5V/20mA, warm white).
As a bonus I now have a 'moonlight' during playback.
First I removed the old bulb - notice the PCB, above LAMP, is badly burned:
From a working SL-10 I found that the bulb uses 12V/90mA. So my LED would be a good replacement. I added a 390 ohm resistor (because I had it - should have been 590 ohm). The resistor is fixed on the -V side of the LAMP position, in series with R430. I also added a LED mounting plastic.
Once everything was put together I found that during play the LED would not dim....(should have read the notes). I changed R430 to different values and ended up with 100K.
To my surprise I now have a very faint light during playing that is just enough to see the record when it's very dark.
Here are photo's of the two states (the camera did overexpose a little).
Stand-by:
During play:
I hope this will help anybody with a dead LAMP.
For those that likes details:
I have to correct the value of 590 Ohm of the resistor that I should have used.
The formula is R=(V-v)/I. V=12V, v=3,5V, I= 20mA. Applied the result is 425 Ohm so the resistor I used 390 Ohm was not too far off.
My newly acquired sl-10's lamp is burnt out also. While I think this is a cool, simple upgrade, how about a direct replacement incandescent bulb? Any idea which one to buy?
